1 - 10 of 10 Posts
Hey there - I searched the forums and found some information but not sure if it gave me the right answer for my issue.
I have a 2000 VStar 1100 Classic with a full Roadburner street pros 2 1/2" exhaust and a Baron Air Filter kit.
I rejetted the carbs with a DynoJet kit and installed everything per the instructions. Starts and runs great apart from 3/4 to full throttle (WOT) - the bike starts to hesitate, drop revs at full throttle and feels like it is cutting out.
I tried the following:
- putting on the choke a full throttle - no difference.
- checked for air leaks with carb spray - nothing.
The only thing I have not done is sync the carbs but I am not sure that would help. I'm thinking that due to my setup, I need bigger main jets ; the dynojet main jet size set up is 110 and 108. I think I need 115 and 112.5.
Any help would be greatly appreciated before I start breaking this down again. Thanks
Can't help with the DynoJet set up. It has always worked best for me using Mikuni jets. Use the chart below to fix you jetting issues. And yes you must sync after anytime you do anything to the carbs.
Here is the entire article.
https://sites.google.com/site/vstar1100kb/home/tuning/carb-jetting
Keep us posted on your results.
Thanks folks. I will go ahead and sync the carbs. If that does not help any, I think I need to go up a size in the main jets with the Baron Air Kit. For a 2000 VStar, they recommend 112.5 and 115.
If I eventually switch to pods, I will up the size of the jets again.
Just remember that Dynojet and Mikuni jets are different sizes in relationship to their numbers. The short style Mikuni jets are the recommended brand for our carbs.
if you still have the stock mikuni needles put them in, increase the mains to 115 mikuni jets in both cylinders and adlust the pms screws out from stock setting a quarter turn. the pipes will cause popping on decell so turning the screws out will quiet the popping..keep pilot jets stock 17.5.
Twinzer said:
Thanks nick57 - any reason you suggest going with the same size jets in both carbs?
I have yet to take the entire exhaust off of the new 1100 but maybe it's like the stock 650 in that the front and rear primaries are of a different inside diameter and different lengths from each other so the flow characteristics may dictate slightly different sized mains as determined by the Yamaha pointy-heads. The flow may change enough with an aftermarket exhaust to warrant using the same sized mains... it's what I would try but ultimately plug readings would determine what's best even if it upsets my OCD compulsion to always have things equal/balanced.
1 - 10 of 10 Posts
