1 - 11 of 11 Posts
the thing is abused, but the price was right...200.00. tank is dented, handlebar slightly bent, tires worn etc...just started to take it apart yesterday. I really do not have experience, but not a complete noob with mech. skills. probably will be asking for advice if I can't find info in a search. I always wanted a bobber, so this is my chance. It does run good for a bike with 54,000. I bought it as a learning project so I guess I'll see how I do. Better on this bike than something more expensive.
Welcome to the forum from East Tennessee. Any pics you’d like to share with us? We love pics here and it sounds like a great project.
Welcome from Atlantic Canada. Lots of helpful and knowledgeable people here so you came to the right place. Sounds like a great deal for a project bike. The 650 (like all VStars) is a very solid and reliable bike. The engines are pretty much bullet proof as long as basic maintenance has been done, so you have a good starting platform. And 54,000 is nothing - plenty of miles left in her.
I'm with Keith - how about some before and then some after pics once you get it up and running again?
Good deal, if the engine is good you really made out at $200 for a running 650.
before you tear things apart too far do yourself a favor, google the V star 650 factory service manual. You can download it free in a scanned pdf format. When you take things apart like the wheels or remove the engine, read thru the procedure in the manual first. Dont start just unbolting things, you will take things apart that you shouldnt.
There are some things to be aware of. For example: the engine in your bike spins backwards, opposite the direction of the front wheel. When you set the valve adjustment make sure you are turning the engine over the right way. Cam chains with tensioners do not like being spun backwards. Nearly all motorcycle engines spin in the same direction as the front wheel, so vstar bikes are unusual this way.
Another important thing: when you take off engine side covers, to change the oil filter for example, some of the bolts are longer that others. Make a drawing and measure the bolts - if you put a long bolt where there is suppose to be a short one, it will hit something inside the engine and do unbelievable damage when you try to start it up.
Also: if you dont have a torque wrench, go get one FIRST before you bolt anything together. Steel bolts into aluminum will strip out the threads before you know what happened. Always use the torque wrench on every bolt and nut on the bike. You can get a 3/8" drive torque wrench from harbor freight for $20, so... no excuses. Get a better one if you can afford it.
Nice. I see it has the pod kit installed. That's probably the easiest mod to get more hp from a VStar. A tip on tools - there are a lot of allen head bolts on these bikes. I picked up an allen head socket set and it's made working on mine a lot easier than with regular allen keys.
Having those air filters under the tank really changes the look of the bike.
Those plastic fake cylinder head covers have no function. If you take them off you will be able to check and adjust the exhaust valves without taking anything off the bike to get to the tappet covers. To get to the intake tappet covers you will still have to pull the carbs.
The only other cover I can think of that is purely cosmetic is the one over the front of the drive shaft to the rear wheel.
Looks like an aftermarket exhaust.
It looks pretty good for $200 bike :^)
When Im riding my 650 the only thing I can see is the grips and the headlight bucket
so I dont care what the rest of the bike looks like, I cant see it
if it runs, its a beautiful thing
1 - 11 of 11 Posts
