I'm feeling like I went nuts lol. Can't tell when the last oil change was done. Or what oil was used on top of it.
I just changed the neutral safety switch because it was leaking today. I also changed the oil with a Yamaha one.
I ended up running rotella conventional oil 15-40. I dumped in 3 qts and took it around the block. My clutch never sipped before and it grabbed normal. So it rips fine in all the gears maybe a little better. However in decel it doesn't feel like it has the same back pressure or the clutch is slipping now. Maybe I'm crazy lol. Does this sound insane?
