The ID number is a six digit code set during manufacture and not rewritable. There are literally 1,000,000 possibilities. With that many codes, the likelihood of the code being repeated between two machines is slim to zero, particularly with the very low production and sales numbers of the Venture/Eluder models. It is a hard pill to swallow, but short of finding the fob or someone interested in hacking the remote control set, you will have to replace the ECU, receiver and transmitter as your dealer has quoted and I would strongly recommend purchasing a second key fob during the repair.
Even if you were to try and guess, it would be a lottery sized attempt. For what it worth, the first two digits of my code are 71. Good luck.
