Just finished my LED mod.
From start to finish it took me about three hour.
Placement is the key and hidding all of the wiring so that you can't see anything.
Still have two more rows of LED's to put on but as of now I think it looks amazing.
I didn't want to over do.
Swomack
Discussion Starter #2
So here's what everything looks like before everything gets installed.
Eight runs of blue LED lights, positive wiring harness with on/off switch, and a negative harness.
This harness has a 10 amp fuse and has the on/off switch.
Here the negative wiring.
I'm going to try to get this done this weekend or for sure next weekend.
Should look great when all complete.
Pictures will be posted soon.
Swomack
Very Nice !
Excellent job, I'm thinking along the same lines after my additional lighting for the rear end. You do realize that your drawing way less than an amp with those strip LED's. They are amazing little buggers.
Your alternator probably don't even notice the small amount of juice these things use.
Your pictures are excellent.
Stay safe out there.
Duane
