1 - 9 of 9 Posts
Long story short, I had to remove the left side crankcase cover to retrieve a socket. I already ordered a new gasket, but when I tried to temporarily re-install the cover I failed.
My shop manual was of no help.
The bottom of the cover likes to get hung up on the frame, and there's a metal shaft going through some of the gears that doesn't line up with it's female slot on the cover.
This has elevated from frustration to fear, as I'm now worried I will need to remove the engine to re-install this. I know we've got some v-star experts on hand around here (I'm looking at you, metric magic), please give any help you can.
When re installing the crankcase cover, pay close attention to the clutch actuator assy. For some reason mine kept binding. I eventually had to put the cover on with the screws just barely started, then hooked up the clutch cable, and then seated the cover screws.i copied this from the kb am i right
Discussion Starter · #3 ·
Yeah I saw that already, I cant even get the cover close enough to start the screws.
Discussion Starter · #4 ·
Can't even sleep this is bothering me so much. Feel like I'm in way over my head, and I'm terrified by the thought that I've somehow caused irreparable damage to something. How can a simple cover not go on the same way it came off.
Discussion Starter · #5 ·
Alright, got the crankcase put back together. The solution now seems obvious.
The starter idle gear, a double gear to the left of the flywheel, has a retention rod that has to line up with a female slot on the cover. This gear can, and apparently tends to, move when the cover is removed. Just had to lift the gear to line it up with the cover.
Spoke with 2 mechanics at local shops, and neither of them pointed me to this solution. Finally just figured it out on my own. I did call another shop, and their mechanic knew exactly what I was talking about. He said so long as you don't pull the gears out, as they mesh together a certain way, and the cover seats properly I should be fine.
He also mentioned a simple test to make sure all is good. After the cover is on, turn the flywheel by hand forwards a couple rotations to make sure everything is turning freely. Then, turn it backwards. Listen carefully for a whining noise similar to a wind-up toy. That's the starter engaging.
Oh, and tape your socket. :)
Reactions: Swampman58
I thought that the best thing to do was to lay the bike down on it's right side. That will help keep the gear lined up between the starter and the large gear. Gravity makes this alignment difficult without some help from this tilting.
Unfortunately, I had the brilliant idea of using 'The Right Stuff' for the gasket, and it only has a working time window of 5 minutes. Fifteen minutes later, I was FINALLY able to get the starter gear to line up with the rod.
You CANNOT do this the other way around by putting the gear onto the cover rod first. The starter gear cannot make it past the stator and the large gear behind it.
One other hint. Unscrew the frame's bracket that holds the wires at the rear of the cover. These will pull out constantly unless you have the slack from the removal of the bracket and the attainment of slack.
I can’t get mine back on 2009 vstar 1100 classic. Swapped stat or out with ease but now can’t get the cover on spent and hour trying to line gear up to get the rod back in (how far should the rod go in? Seem like it should go all the way to the backside and lock in then slide cover on but no it just won’t go on!
I pulled the gear shaft out along ways n held it there with channelocks, then I started that shaft first followed by lots of shaking n twisting n went into place. Lastly I used a small pry bar n popped cover over the fram on bottom. I feel for u cuz I to thought I broke something n was super frustrated y the darn case wouldn't go on!
1 - 9 of 9 Posts
