Well, to update the post, the grips are on and everything went fine. Only a couple of things that I would tell the next rider. There is a little bit of play with the throttle side grip so I need to devise a spacer to take care of that (only about 1/16"). Also, the glue provided for the clutch side would not come out of the little bottle. At first I thought is was dried up, but I pried the top off of the bottle and could see it in there. So I just spun the glue around the bar with an allen wrench then immediately applied the grip. Worked like a charm.
