1 - 10 of 10 Posts
Be sure to add the mentioned blade fuse.
Many of us have had the meltdown
Try it with the bike running, not just with the switch turned on.
Yep, that's exactly what it was. With engine running, all lamps (and accessory switch) have power. Once bike is running, you can turn it off with switch on right handle bar and all lights will remain lit.
BTW the plug is behind the metal plate in the headlamp housing. If anyone ever needs to get in there, just remove the 2 bolts holding the plate in place and there's the plug, nicely hidden! :)
Thanks for the reply! Very much appreciated!
1 - 10 of 10 Posts
