Hi and thank you for your message. You can understand where I am coming from. I am holding on to my 30 year old Toyota for as long as I can. My V Star is 16 years old now and I have never had to do anything to it other than change the oil and the tyres. I have had no problems. I treat this motorcycle very carefully and it will give me many years of riding.
Does your V Star have a FOB or a KEY. My 2006 only has a key. It had key recognition but I changed that and now any key that I get cut at the locksmith's will fit. I like to do all my mechanics and vehicle servicing myself and I can see that you do also. It is so easy with an older vehicle. The things that I really love about my V Star 650 is that it is fully air cooled so no water or coolants to worry about. It has carburettors that I can fix myself. No fuel injection. It has adjustable tappets so no valve shims to worry about. It has shaft drive so no chains. The whole motorcycle is very light and at 70 I can still handle it ok. I hope that everything goes well for you and your motorcycle into the future.
This is a good tip and it works to check the oil on a V Star 650. I use an old bike mirror taped to the end if a stick.
You just sit on the bike level it up with your feet and use the mirror to check the oil level.
