1 - 20 of 22 Posts
Maybe this has been addressed, but I couldn't find anything from searching. The mid shaft nut issues that the 02 and 06 1100's had, is this a big issue that people have seen. It seems like if mainly affected those years, but after 06 was something put in place to fix the problem from happening? Seems like a huge deal, and honestly has me kind of curious. I would hate to be going down the highway and the real wheel lock up because the drive shaft snapped and got in a bind. I'm sure you guys will put my concerns to ease.
Hatchet, I don't understand you not finding anything on the mid shaft issue on here. I posted my issues and so did many others. In any case, Yamaha came out with a larger shaft to help solve this issue. I'm not sure on the year they came out with this repair; maybe Mick can enlighten us. One thing you can do to set your mind at ease is to have a look at the nut. If it hasn't moved, stake it in place. If it has started to move, torque it back up and stake it.
Almost all years of V Star 1100 have had the mid shaft issue. You have to realize that the greatest numbers were sold during the years you listed....so of course we see more instances of it. As much as you might hear about, it is still a relatively uncommon occurrence. I don't think Yamaha ever changed anything except a more aggressive staking of the nut....and that wasn't until 08 or 09 if I remember correctly.
If you want to avoid it for sure. Just stack the nut in place and you'll never have to worry about it.
Also..the rear wheel will not lock up...the bike will run and move just fine, it'll just be really noisy and you'll know something is wrong. I've seen guys ride over 100 miles with it broken. It did beat things up a little in the shaft area like the speedo sensor, but all was easily fixable even after all of those miles.
Even if it does break, it's a pretty simple and inexpensive repair. I did it 20,000 miles ago and have not had an issue since. Nor have I seen anyone have an issue with the repair in all the instances I've seen over the last 12 years.
The 1100 is an incredibly durable machine.....
I appreciate the response. I tried to sift through all the posts when searching the issue. Maybe I wasn't searching the right key words. I was planning on taking it apart and taking a look either way, I was mostly curious if it was an issue towards the end of the 1100s reign over the vstar line and if they came out with a fix I didn't wanna stake it for nothing. thank yall for the info. Definitely helped.
08 was the fix thank goodness. After I got my bike and started to read that it freaked me out. From what I have read there have been no serious injuries from this failure most common is a brown spot in ones underware thank God.'
My '05 VStar 1100 just turned over 25,000 miles when I noticed the whining noise. Started researching, then I did a visual inspection and found the middle driven shaft broke at the very end; I had to bring the nut into work with me to get the remains of the shaft out of it - it was staked and did not come out easily. For my machine anyway looseness of the nut doesn't seem to be the root cause of the failure.
I am in the midst of removing the engine and am planning to take it to a local machine shop to have the shaft end milled flat and tapped for a grade 8 bolt (M8-1.25 x 16 mm).
I'm still wondering about the original nut; should I mill it down in height or can I find one with the same flange that is thinner? What's the spec on the nut, anyone know?
When I start machining my own bolts or drive shaft, I want someone to just shove me out of the plane without a chute. I ride an average of about 20,000 miles (per year) on my '07 V-Star 1100 Classic, and my Certified Yamaha mechanic is a necessary and valued part of my "team". That said, I admire your skills with machine tools and wish you all the best.
OK I guess I'm the stupid one here but what exactly is the mid-shaft issue? I have an 06 with just over 24K. No issues thus far but what do I need to look for or check to make sure I don't have any problems? From reading the posts I'm assuming a nut somewhere works loose.
Thanks
Thanks Nick. As much as I have looked at that wiki page I cannot believe I never noticed this before. Maybe I did and just didn't pay attention. Wish I had seen this two weeks ago when I had the rear tire off.
I have an 02 650 that is starting to have a high pitch whine in the tranny area, almost sounds like a whistle.
Is this a symptom of the midshaft problem?
Next time someone does this I was curious if it is possible to share a pic of the midshaft but and bolt not sure what it looks like but kind of have an idea and wanted to see if what I am thinking is correct
I noticed this is your first post. Might I suggest posting an intro in the new members forum so we can all get to know you a little.
Here's a link to a thread where someone did the repair and posted some pics. Basically it's the shaft at the transmission that the driveshaft slides onto.
I picked up an 05 1100 with a speedometer problem and low and behold it is a sheared mid shaft at the threads. It just boogerd up the sensor and pushed it out some but all looks fine. . Someone (previous owner or mechanic) has already taken the Nut out. I will be doing the drill and tap repair next week for piece of mind but I read some people just throw the nut away and ride forever on it like that since the U joint will not back out. Any thoughts?
I've known several that successfully completed the repair without any issues. Also knew one who broke drill bit into output shaft, that one didn't turn out to well. Just take it slow when drilling with sharp bits and you should be good.
I'm still puzzled by this being an issue with the XVS1100, but hardly every heard about on the XV1100, which have the same set-up.
1 - 20 of 22 Posts
