I have a question about the Acceleration Duration screw.
From this article : http://www.roadstarmagazine.com/2003/07/how-to-adjust-the-road-star-accelerator-pump/#more-149
and a virtually identical description on another form.
My bike is a 2003 Yamaha Road Star. All stock when I got her.
My basic problem is that I did a carburetor rebuild on my Mikuni BSR 40 and instead of improving matters, things go worse. Hitting the gas did not make the engine take off quickly as it should, and there is now a lot of backfiring through the carb.
According to that article, the bogging problem could be alleviated by adjusting the 'Accelerator Duration Adjustment Screw' outward to increase the amount of fuel squirted. However, upon investigating this screw, it seems to be floating. Not that it's loose, it just never touches the black plastic piece underneath that is supposed to adjust the amount of gas being squirted when the throttle is hit.
Does anyone know approximately where this end of this screw should be touching? According to the article, turning the screw (it is secured by a lock nut) clockwise should decrease the amount of fuel provided. So, just guessing . .. being retracted so that the screw never touches the lever underneath, it should be squirting the maximum amount of fuel.
Does anyone know an approximate starting position that this adjustment screw should be set at? Is the screw too short? There is also one on the back side that sets a quantity. Yes, confusing, they both say quantity, but really one is duration and the other is quantity.
Also, all that I have done, engine wise, besides new plugs, is to put on a high flow K&N filter. Not the small one that replaces the OEM, but the triangular large RK Series that requires a new outside plate to hold it in place. None of these changes should be causing the backfiring, sputtering, and bogging down when the throttle is applied. I've made no changes. I used the needle valve that came with the kit, the Non-adjustable one with a single notch and the main jet replacement was the same original size of 165. Testing is done with the air box off anyway, so air flow availability is at maximum.
I would love to hear any other suggestions on solving the backfiring problem. So far, I have increased the turns outward of the Pilot Jet screw from the original 2 1/2 turns out to 3. I have a replacement Needle Jet on order that has cut slots so that it can increase richness. I don't know yet if I should be changing things into a more lean direction. Advice on that would be greatly appreciated.
Thank you in advance for any advice.
