1 - 20 of 22 Posts
Okay guys I have my 2006 Stratoliner pretty much stock except for a slip on exhaust it was added by the previous owner I have about 38,000 miles on it now and it has an intermittent problem with bogging down or skipping it seems to be mostly at steady throttle and it doesn't do it all the time it seems to be more in the 60 to 70 mile an hour range than anywhere else that coupled with the fact that I I'm only getting about a hundred and twenty miles out of a tank of gas makes me wonder whether I should be looking at fuel or electrical I suppose it could be the valves need adjusting or maybe the throttle bodies are out of sync but I would like to find some cheaper alternatives first any thoughts are appreciated thanks in advance
The obvious question is where are you in the maintenance schedule? Are you due for plugs, air filter, valve check/adjustment, fuel filter... ?
Has this been going on for a while and getting worse? Could it be just one tank of bad gas - that could be fixed with some SeaFoam.
Just had air filter plugs and oil change done. Nothing abnormal noted there. It's been going on for about two weeks. Can't say it's getting worse. To give you an example. Left for work this morning bike started right up pulled out on my road bike accelerated smoothly all the way to the end of my road got out onto the main road accelerated smoothly and if not slightly rapidly because of traffic reach speed of 60 miles an hour maybe more like 65 this holding steady throttle riding and it kind of started bogging down for lack of a better way to describe it if I lightly and I mean very lightly like it doesn't even change the speed of the bike open the throttle it seems to correct the problem but only until I hold the throttle steady again stopped at the local gas station got a cup of coffee hop back on the bike bike started right up drive the rest of the way to work with no problems max steady speed of about 55mph
Try the seafoam and track your mpgs as accurately as you can for a few tanks of fuel. Its a good indication of how well the bike is running.
I have been experimenting with running ethanol free gas, 87 regular, in my 650. I have not gotten any change in mpgs, but I have noticed the bike feels a bit more responsive with the pure gas than with the 10% ethanol.
Its just a feeling on the throttle - with the pure gas you put some pressure on the throttle and the acceleration is right there. With the 10% ethanol I feel like I need to twist the throttle a bit and there is a bit of lag before the engine responds.
Its that real or is it all in my head - its hard to say.
The only other thing I can suggest if you think the engine is getting a bit off is to check the compression (if you have the gauge).
Your bike has hydraulic lifters, but the intake and exhaust valve pairs each work off one single lifter. So it is possible for one valve to become a bit off from the other, but from what I have read its pretty rare.
Its also a lot of work to check them, you have to take a lot of stuff off the bike to get to the tappet covers, and then if a valve is off its a bit complex to get it to match the other one.
Just a possible answer. See how it runs with the seafoam, and see if you can make any kind of measurable reading that you can track (mpgs or compression....).
If I was the head of SeaFoam sales, I would give the first bottle away for free
go ahead, try a few ounces in your tank. All your cool friends are 'using' it. You want to be cool dont you?
Fixing a motorcycle with SeaFoam really is like the Veterinarians handbook "how to care for Horses".
broken leg: shoot the horse
Blurred vision: shoot the horse
Cracked hoof: shoot the horse
Missing teeth: shoot the horse...
That's pretty good lol. I do like sea foam and I don't suppose I could hurt. I already have some I had for an old riding mower I have so worth a try I guess
I think we found the reason why the bike was for sale in the first place. Modified exhaust is often the culprit. You just can't change the exhaust back pressure without doing other things to the intake system. Changing the exhaust system actually means that you are "de-tuning" the motor. The original exhaust and intake go hand in hand with the good operation of the motor without it being too noisy.
how much the aftermarket exhaust affects the engine depends on how radical the exhaust is
A slip on 'muffler' that is just louder but still has some baffles wont affect the engine much by itself. It will barely increase the HP, and you can often get away with the stock jets.
To get a noticeable increase in HP you have to also open up the intake air filter and plumbing. Then you will need to change the jets and the PMscrews to allow more gas to match the increased air flow thru the engine.
There are lookup tables for different intake and exhaust mods that will tell you which jets to use and how far to turn out the PMscrews.
If you put straight pipes on the exhaust, no baffles, then you can lose HP. It gets complicated at that point.
You should be able to get a good read on how well the jets and PMscrews are set looking at the plugs, if they are fouled out black, or if they are running hot and look like they are melting...melting... oh my world...what have you done?
Having said all that, if the bike was running ok for the last two months and now it seems like the performance is degrading, there has to be something else going on.
EDITED: looking back,... the bike is a 2006 stratoliner. Im not sure if it has carbs or fuel injection. If the bike is fuel injected then you need to re-map the ECM to give it more gas, or have it flashed with a new map by one of the websites that does this, to match the exhaust and intake/air filter on the bike. But still, if it was running ok last month, that should not be the issue.
+1
Can you get the factory can back on, does the original owner still have it or do you have it.
I have a K&N filter and at one point tried the D&D slip on. I have a power commander and can send different maps to the ECU. I found that the map that Power Commander has for downloading on their site causes the exact symptoms you have. At around 70mph it would drop out and back in like its starving or running out of fuel. Every mile or so at say above 65mph it bogged down like running on one cylinder even thou it was on two. I found a better map and it pulled like a freight train. I liked the deeper tone of the factory can over the D&D and went back to it and had to re-map for that setup.
You will either need the factory can or re-map to the after market one. In my case, re-mapping also involves disconnection the O2 sensor.
Discussion Starter #12
No chance of getting the factory can back my issue is that the problem is intermittent. If we're a steady problem easier to diagnose
Intermittent issues suck. If it's not a fuel or fuel/air filter issue, I'd also check for an air leak. I'm pretty sure your bike has a carb vs. fuel injection. Check all your exhaust connections to make sure they're tight. Also check your carb connections behind the air filer. I'm not familiar with your bike, but it's not uncommon to develop air leaks on my roadstar at the manifold creating some of your described symptoms. Good luck!
Discussion Starter #14
Intermittent issues suck. If it's not a fuel or fuel/air filter issue, I'd also check for an air leak. I'm pretty sure your bike has a carb vs. fuel injection. Check all your exhaust connections to make sure they're tight. Also check your carb connections behind the air filer. I'm not familiar with your bike, but it's not uncommon to develop air leaks on my roadstar at the manifold creating some of your described symptoms. Good luck![/QUOTE
Yeah it drives me crazy the bike is fuel injected and I can't locate an air leak to save my life. Getting ready to try the sea foam this weekend and see if that helps
Discussion Starter #16
That's the point I'm am trying to get across. I bet that when it bogs you can open it up and she will pull hard. The flat spot is due to improper mapping due to the slip on.
I get that point but why would it be intermittent why not all the time. If I had a constant flat spot all the time I would say okay maybe I'm just not understanding.
I had this happen one time and had a friend who has been riding bikes for many years look at my bike. 1st thing he did was raise the bike and spin the wheels to check and see if my bike had a brake caliper that was hanging up.. Sure enough,, it did!! On mine the caliper would stick a little - heat up the pads as I rode and then get a boggy feeling.. Something else to check maybe if nothing else works:smile:,,, personally I would do it before anything else cause its simple and free!!!:grin:
Discussion Starter #18
I had this happen one time and had a friend who has been riding bikes for many years look at my bike. 1st thing he did was raise the bike and spin the wheels to check and see if my bike had a brake caliper that was hanging up.. Sure enough,, it did!! On mine the caliper would stick a little - heat up the pads as I rode and then get a boggy feeling.. Something else to check maybe if nothing else works/forums/images/StarbikeForums_2015/smilies/tango_face_smile.png,,, personally I would do it before anything else cause its simple and free!!!/forums/images/StarbikeForums_2015/smilies/tango_face_grin.png
I'm going to check that cause of gas mileage but you can hear and feel the motor bogging down. Almost like it's not getting fuel but if twist the throttle it will go. I'm liking the idea of a remap as previously mentioned just don't understand why it's an intermittent problem.
KCW ... you have a competitor salesman.
SeaFoam is not a business/money thing
its a religion!
well more of a cult really
and the metal cans are really cool....
1 - 20 of 22 Posts
