Need a 5pin-LED-hazard-4way turn relay for my 1999 yamaha vstar 650
i seen an aftermarket that would just plug in to my harenes harness i would like to get by with no cuting enuff of that has been done before I got it 4 year ago.......any help on where i could find this relay I would be very grateful..
So, the reason for 5 pins is the self cancelling function. A cheap 3 pin from your local auto parts store will fix you up but lose the cancelling. You don't have to cut any wires just pull the spade connectors out of the block at the flasher.
You can use any three pin unit as long as it has 1/4 in spade connectors.
Sent from my SM-G930V using Tapatalk
