1 - 17 of 17 Posts
So I bought new lines to accomadate the new height of my bars and when it came to my clutch cable it appears that for some awful reason I'm unable to adjust the cable correctly. It's too sloppy and loose. Not tight. Can someone explain to me me what I may be missing?
What year and model of bike?
Normally the issue is at the lower end. Here's adjustment info.
Yes it can be too long. Hopefully I can explain. The outer sleeve can be any length, wrap it around the bike if you want. The important measurement is the free length measurement, see pictures. The free length is the amount the inner cable slides in and out of the outer casing. Slide the inner cable all the way to one end to measure. If the free length is short there will not be sufficient travel to operate the clutch. If the free length is too long there will be too much cable to adjust tight enough to operate clutch. Measure the free length of old and compare to new one. If they are the same, within 1 to 1.5mm the cable is correct. The attachment at the clutch end is a fixed distance and all adjustments is at the lever using the threaded cable end into lever and locking with thumb screw. Should be a bit of free play at lever, see photo. This is always difficult to explain without showing, so hopefully it made sense.
When was your last oil change?
I thought my cable needed adjustment because I did not like the way it shifted. Well, after I changed the oil. Big Bertha shifted much better.
The bike has been in it's modification phase for several months now. Pretty much inoperable during that time period....thats interesting....oil change you say?
If it's been sitting for months maybe clutch plates are stuck together and not releasing. KCW explained this not to long ago in another post. I couldn't find it so hopefully he will chime in.
Discussion Starter #12
When I go to compress the clutch lever I feel a slip and the bolt down there that i tightened loosens up as well.
Are you saying that number 14 is spinning on number 10. If so you need to hold number 10 after adjusting with screw driver while tightening number 14.
Discussion Starter #15
When I compress clutch lever
#14 loosens up which makes
#12 dislodged from
#9
I would reseat #12 back into #9 because of a rectangular cut out in #12.
Do you think I may have over tightened the screw?
By the way I very much appreciate your feedback everyone.
#12 dislodged from
#9
I doubt it. Back off 14 and look at theards on 14 and 10. Keep us informed.
Discussion Starter #17
#12 dislodged from
#9
Roger that
1 - 17 of 17 Posts
