Can anybody identify for me what wire goes to the brake lights and which are for the directionals from this plug picture?
Hope this helps. You can confirm with a volt meter.
BACK taillight assembly:
Yellow - BRAKE
Blue - RUNNING LIGHT
Black - GROUND
Brown - LEFT TURN SIGNAL
Green - RIGHT TURN SIGNAL
Yellow - BRAKE
Black - GROUND
Yellow - BRAKE
Black - GROUND
Thank you!! I have 3 wire LED Turn Signals and a Cat Eye mounted on the axle so I need to do some fancy wiring it seems, but thanks for letting me know which wire is for what, big help!
