1 - 1 of 1 Posts
I need to replace the rear wheel on an '01' 650 vstar. Does anyone know if the rear wheel for an 1100 vstar will work? I know that the brake system is diff, drum vs disc, but was not sure if the drum would be able to bolt to the hub on the 1100 to convert it for use on the 650. I have found that the part number for the hubs are diff as well. I am also not sure if the drive side will match either. Any info will be much appreciated.
1 - 1 of 1 Posts
