1 - 20 of 30 Posts
2006 Startoliner
Just bought a 2006 liner With 15000 miles. Previous owner took for the most part good care of her. The neutral light does not work. Tested all the other safety switches. Everything works correctly. Just the N light is out. I think I have located where the neutral switch on the engine is located. I think I will have to pull the exhaust and 1 oil line not sure yet.
Do you think it is the neutral switch located on the engine that is keeping the light from illuminating?
If the bike is starting, seems the switch it self is working. The bike would not start if neutral switch was out without you holding the clutch lever in. Sounds like the bulb is bad.
Reactions: faffi and Boog
2006 Startoliner
I was afraid of that. I have searched the web and have not seen where any stratoliner have this same problem. A new gauge cluster is $600-$700 might just go without the light. Looked for a used one but nothing so far. Les do you know of any Online motorcycle grave yards?
2006 Startoliner
Hey les or anyone else is the speedometer serviceable? Can it be opened and the lights be replaced or Are they a permanent micro led? Any place to send it to have serviced?
99 Roadie
@Jaguartech , here's a question for you. ;)
First you would have to make sure it isn't a problem with the switch or harness.
Instrument comes out of its case easy.
Indicator bulbs on my roadie are quarter turn panel mount type.
Will get a bulb number and post it later.
Blackstrata, can you post a pic of the back of the circuit board of the cluster?
I knew our resident speedometer/odometer/dash expert would come thru. :unsure:
Reactions: stratsurvivor
2006 Startoliner
Well the bike will start in neutral without pulling in the clutch. I did pull the tank panel and looked at the wire harnesses. Everything looked perfect. I did not unplug them all to look at the pins. Les did mention if the bike starts without pulling the clutch In that the neutral switch on the motor should be good. I have not tracked the wire from switch to speedometer yet to see if there is an issue with it. I have been researching where the wire runs. Looks to be a connector above the battery but everything looks good there as well.
2006 Startoliner
In all my years of being around motorcycles and ATV I have never known a N light going bad?
Reactions: Boog
2006 Startoliner
Discussion Starter #12
I will post a pic of back later today. Thanks for the help!
I had the neutral light go out on my 1100. It took a 24 bulb. Replaced all bulbs in dash with LED. Worked great.
99 Roadie
Expert?
Stretching it a bit🤣
Here's what was in a roadie.
Notice how l used the ink pen 😜😜
Expert?
But it's not a black pen. 😂🤣
I am probably just a weird guy with a weird sense of humor but I find this kind of stuff funny...not groan button funny but funny nonetheless..(y)(y)😁😁😁
I found something, it looks like there is a diode block near the fuel cut off relay . if the one diode I have circled is bad , the bike will start in neutral but the light won't work.
97015
2006 Startoliner
Discussion Starter #19
I can do a lot of stuff but electrical I shy away from. Plus I am color blind. So what would that diode look like ? If it was bad would just the wire from switch to plug under seat need replacing? I saw in a schematic that the neutral switch wire went from switch on motor to a plug under the seat. Then from there to the speedometer.
Well being color blind sux in electronics trouble shooting.
You need to take a multi meter and with key on , ohm from the connector shown ( unplugged ) to ground ( battery negative)
switch back and forth in and out of neutral. It should be max ohms in gear to close to zero ohms in neutral.
97017
1 - 20 of 30 Posts
