I got a new carb for my 250 and it's missing a screw its threaded with small hole in bottom is this ok my stock carb this area is closed what do I need to do ?
Looks like the PSM screw housing. Stock there is a cover there, that most remove to richen the mixture up some.
Can you look down in it and see a screwdriver slot?
If you can then the PMS adjuster screw is there and can be adjusted to 2 to 21/2 turns out from lightly seated.
Pulled up carb diagram, look at number 10 in picture, that's the PSM screw, shows to be in the hole you have circled with a cap, #11, that covers it.
92673
