1 - 12 of 12 Posts
I currently own a vstar 1100 custom 07
alot of customs, love the bike
7k miles and i'm having starter issues, i came to this site after seeing there are many knowledgeable users here that might be able to help me figure this out.
i also own a suzuki gs750 03
Welcome to the forum. SO........... Spit it out, what is your starter problem??
Welcome aboard. Maybe you should post a pic of your starter problem. When you read more of the forum you will get what I said.It's just a little fun a games we have around here.
Like ol' Surgar Bear said what's your starter problem? Give us some more details. There's a lot of 1100 riders here.Sparkyd could answer you ? if we new more details. He has an 1100 custom also with lots of mods.
Basically, i've narrowed the problem down to the starter clutch
i'm just wondering if wear on the gear idle 2 will be visible enough to know whether or not i need to order it for $100 or use the existing gear
it's a 13k mile bike, and i'm guessing i killed the starter clutch by giving the bike throttle when starting it
Are there any other parts other than a idle 2 gear / bearing / gasket that i'll need with a somewhat low mile bike? The starter works fine (spins/sounds normal)
other than giving it throttle when i would start it, i hear that custom pipes / tps / and not jetting it are other potential reasons why the starter clutch took a dump... either way i'm looking around $400-500 in parts to get my baby back on the road...
Banned
Welcome to the 4M!
I'm sure somebody will jump on soon about your starter problem. I'm a bit confused about the "idle 2 gear"?? Are you saying the starter spins but the engine isn't cranking ?
And in the first picture, are those rocks or do you have a giant rabbit problem? :D
Welcome to the 4M!
Yes, the starter free spins without cranking the engine
it started to get dodgy and needed a few tries to start the engine, then one day it just got really bad and started to free spin
the idle 2 gear was recommended to be replaced in another thread i read recently (but i will inspect the gear before ordering the parts)
and yes, those are rocks ;p my mini world strongest man atlas stones, all weighed and engraved with #'s, there are big ones not in the picture ;)
blue flames at night from the tailpipes (loud audio)
Bike Running + Walk around (low quality)
chillbman idle gear 2 is 1 of the parts that goes bad, Heres a picture of a bad 1 if it has any marks on it its bad. The 3 parts behide the fly wheel is the starter clutch an thats the parts you need to replace and the idle gear 1 lower left has been upgraded to help on kick back Yamahapartsnation.com has the kit for $295.
Idle 2 gears? Giant rabbits? Atlas stones? Blue flames? This is all too much for me!
Nice bike chillbman! And I too dig the pipes! Maybe the starter issues stem from the missing front fender? :D
Good luck with the issue, I'm sure you'll be provided with the right info! It's up to you to sift through all the "filler" to get what you're looking for! :D
1 - 12 of 12 Posts
