1 - 20 of 24 Posts
Greetings, everyone. I got licensed in 2012 and bought a 2003 Yamaha V-Star 650 Classic. I'm having a great time with this bike, but I think I will be upgrading to a bigger engine sometime soon.
However, I do have a problem with my bike not starting. I have read several posts but was unable to find a solution from the several similar posts I read. My bike failed to turn the engine and I decided to buy a new battery. This worked for a few days and it went back to the same. I had the new battery tested by the seller and it came back with not issues. The bike, however, still fails to turn the engine. When I turn the key I do hear the humming sound, the kick stand is up, the bike is in neutral (green light on), and kill switch is on. When I attempt to start I hear clicking sound and a faint attempt to turn the engine like when the battery is dead. Can you help or point me to a post with a possible solution?
Banned
Welcome to the 4M.
Sounds like your battery isn't being charged by your alternator/generator. Recharge the battery again, fire up the bike and while it's running put a volt meter across the + and - battery terminals. You should see a little over 14V on your meter if the system is charging your battery.
Banned
So the new battery worked for a few days and now it won't work. It isn't getting charged, for whatever reason. Can you jump start it from your car's battery?
Yes it can be done. I have done it several times. But Yamaha does not recommend it. They told me they prefer you do jump from a power starter or a charger jump start.
Sent from my LG-MS770 using Motorcycle.com Free App
I know.I had to jump my bike due to my alarm being installed normally when it needed to be installed differently with the starter kill
Welcome to the V Star 650 World. I bought mine a few weeks ago, and after about 500 miles of around town and some highway. I've had it up to 70 mph and felt there wasn't much more. I over heard a conversation once about a guy having this issue on a Suzuki, and he had a bare wire somewhere in the wiring that wasn't allow the start to roll over. Fair warning, I am nowhere close to being mechanic, but the guy said he found the issue, soldered the wire and BOOM, problem solved.
welcome vstarjag, from another alabamian! what part of bama? if close by, i could help you figure out the issue...
1 - 20 of 24 Posts
