I picked up a one owner '03 1100 last week with unknown miles (owner estimated 30k, but the original tires were like new, so I was skeptical) for a good price. Garage kept most of it's life, so it's very clean. I bought a new battery, hooked it up, and was thrilled to see that the odometer reads 4700, so the owner was way off. This matches the wear on the tires. Owner parked it two years ago (I suspect more) due to health, and it supposedly ran when parked. It has a 1 into 2 Mikuni setup and aftermarket pipes (original carbs included, along with original pipes).
Anyway, upon hitting the starter button, I get zero response. Everything on the bike works, but she doesn't even pretend to try to start. Kickstand up, clutch in, makes no difference. I jumped the clutch switch and that didn't do anything. Also, the old gas has stuck the fuel cap. I can turn the key, but it has minimal resistance, so I don't think it's retracting the cams. Either way, the cap won't come off.
Suggestions on either? I won't have time to hit a test light or continuity tester until Wednesday, and I have to find where the fuses are to check those, but I wanted to know if there was a typical smoking gun. Thanks for the help, in advance.
