There was simply too many posts in this topic to read it all, but there are a lot of the current technology that does not appeal to me. And some that does.
For instance, I like drum brakes, but am OK with disc brakes also. I like the safety provided by ABS under a panic attack or if the surface unexpectedly turns slippery, but I dislike the added weight, the added technological complexity, the added trouble of changing the brake fluid, and the extra braking distance that is the result for many systems that intrude too early. On ice and snow, for instance, I would like to be without ABS, because braking distance gets longer with ABS. The ABS on my son's MT07 is good because on a good surface I can still do a stoppie without intrusion from the ABS, but the Super Tenere will not allow the rear to get airborne, which can spell trouble when braking hard on a bumpy surface with unnecessary prolonged braking distance. The pros and cons more or less balance themselves out, meaning I can live with and without ABS. Detest linked brakes, but I know they can be a life saver if one system (front or rear) should fail completely. OTOH, if the system is serviced and looked after, it will not fail.
I do like cast wheels and tubeless tires because they bring a huge increase in safety, something everybody who have experience a puncture leaned over in a corner will know. I like center stands and kick starters too, but I also like my bikes to have an electric leg. And I like flat seats that allow me to move around. And a proper key to work my ignition lock.
I like analogue instruments and mechanical trip meters. I also like all information available at once and get really #&"&! when I need to scroll to find the clock or the trip or the temp or the whatever. Older bikes and cars used to have all the info they could deliver displayed at all times. Yes, modern vehicles can give more information, but at any given time they offer less than most older bikes.
There is only one thing I like about fuel injection. No, two. I like that I can park the vehicle for a year and it will fire instantly, unlike gummed up carbs. And I like that FI compensate for temperature and altitude etc. But so far I have yet to use and engine with FI that could deliver the smooth response of a well adjusted carb. And the complexity, what with all the sensors and brains etc are off-putting. To me. Ride by wire, various power modes, traction control etc fail to excite me.
Active suspension is another major complexity that really does not bring a lot to me, who always ride solo. Sure, it is nice to me able to adjust the suspension on the fly, but if you are going to service the suspension yourself you will likely soon want something a bit less complicated to work with.
Variable length intakes, shim-under-buckets for valve clearance adjustment, spark plugs hidden so deep you need to remove the tank to reach - and the tank has enough wires and hoses and seals to drive anyone mad that must first be removed - irritate me. Coolant system that must be drained before you gain access to measure valve clearances also.
Last, but definitely not least, I like motorcycles that looks like motorcycles, not like insects from outer space. Yes, I am old fashioned.
How's that for a rant 😄
