I am certain this has been a topic a few times but my situation varies slightly. I recently purchased a wrecked 2014 bolt from copart and was excited when I got it home only to slap everything together and find out there is no spark. So bike has fork damage mainly and some damage to handlebars, all in all bike is sound and cranks but no spark I was able to get the dash working, I'm getting a code 24 and code 19 research tells me 24 is o2 sensor( aftermarket exhaust has no slot for o2) and 19 is kickstand curcuit I've tested switch it works fine doesn't appear to be a break in line. I have checked killswitch resistance it's fine coil resistance is 2-3k I'm assuming normal (not getting power to it ). Transmission fine. The bike went down on right side and got bike with no keys (figured I'd put that at the end) I did jump positive and negative pins on ignition, don't know if bolt works that way. If you can't tell I've worked on at least a light bulb before 😛 . But I'm getting no spark whatsoever. I figure it's something simple because none of any wires look frayed or damaged except feul pump from tank slouching off ( still works) brand new battery (I'm a distributor for motobatt). So very sorry for the long post I just wanted to get as much information across as possible! I've tried 4 forums with no response hopefully one of you fine people can help a fella out!!
