I have had my Bolt for a while now and as luce1979 quoted in his post about a Ticking Noise, I am also experiencing a similar issue.
It appears to be more prevalent once the engine is warm. It happens during low to mid throttle in all gears. Clear ticking/fluttering noise. Doesn't appear to come from any particular cylinder. Below are 2x shares to a Video and a Audio clip of the noise. They are not perfect and the Video does make it sound alot worse than it actually is. At about 1.30 in the Video when I am giving it partial throttle in neutral, that ticking noise is what can be heard clearly while riding over a slip on exhaust (not fitted in video) and through shooter ear plugs with helmet and face shield on.
Any ideas or information is greatly appreciated.
PS it is going in for its 5000K service in around 12 hours.
Audio File:
https://www.dropbox.com/s/val3coxnowxwc6b/Bolt - XVS 950 R - Engine Noise.m4a?dl=0
Video File:
https://www.dropbox.com/s/eznl4o9tb01wdjp/20140917_191108.mp4?dl=0
As discussed in the thread from luce1979 quoted below.
Audio File:
Video File:
Proud owner of a new Bolt R-Spec and love this bike.
As most of you know it's platform is the proven 950.
I've noticed a ticking noise coming from the engine and not sure if it should woory me or not?
Symptoms:
1. Not at idle
2. Not at low RPM's
3. Starts at half throttle and is more pronounced when engine is fully warmed up.
Sound: Ticking and as throttle opens becomes more pronounced. Can be heard over windnoise and muffler.
Any ideas? Valve adjustment? Lifters?
I'm not qualified to wrench the bike myself and not sure if this is a common issue with 950's?
Would appreciate any and all advice.
