· Registered
Reaction score
23
just curious did the oil and filter change over weekend. 4 ltrs is the user manuals recommendation with the filter change as well. Went back out after and checked cold the oil level. Looked abit over the fuel mark on dip stick. I am guessing as the oil settles into the filter it will be okay? I mean if the manual says 4 lts then that's correct surely. Cheers
· Administrator
Reaction score
11,377
the U.S. manual calls for 4 quarts = 3.7 liters. so if you put in 4 liters, that's a little above the U.S. manual recommendation of 4 quarts. that could explain it. and are you making sure to check the dipstick with the bike as level as possible? even if you are just a tad over it should be OK so i wouldn't worry about it.
· Registered
Reaction score
23
Discussion Starter · #3 ·
thanks for that
· Administrator
Reaction score
11,377
someone should have checked my work, i was going based on how i've been changing the oil on my '09 950 since always. here's the actual owner's manual with specified amounts for both with and without replacing the filter during an oil change. i just always replace the filter and i always put in 4 quarts and it works fine:
3.7L or 3.91U.S. quarts without filter replacement
4.0L or 4.23U.S. quarts with filter replacement
you were actually putting in the correct amount. so if you're reading the dipstick with the bike as level as possible and it's reading high, i would make sure you're running your bike for a few minutes to heat up that oil before you drain it. maybe you're not draining it all out before you add more. but again, such a small amount is not going to hurt anything.
