1 - 2 of 2 Posts
Was just wondering what tools anyone is using to remove the two oil drain bolts beneath the crank case on the raider engine. I know this bikes engine may be similar if not the same as other star bikes (road liner I believe?). I have been trying for two weeks to find a box end wrench I didn't have to grind to size to Un screw and re torque the oil drain bolt beneath the crank case.
Discussion Starter #2
Update-
So I managed to figure it out exactly. The way that you have to position the wrench will largely influence the outcome. But it isn't just positioning over the bolt head. You need to position the wrench at an angle to be able to turn the bolt. The crank case was shaped to allow enough space to do this sort of work primarily with it standing straight up. Will include pictures later on the technique I noticed was required to do this. Hopefully this helps someone.
1 - 2 of 2 Posts
