New member here….I have a 2007 vstar 1300 touring with low mileage and no past problems. I did my oil change last fall and used the same oil as in the past Yamalube 20W50 and a Yamaha new filter. No problems at start up and then after 5 minutes riding the oil level light came on. Tried removing some oil so it was perfect in the siteglass, tried adding a bit, no change, light comes on after a few blocks. After reading on the various forums about the problem I thought I would change the oil, filter, and oil level sensor at the bottom of the engine in the spring. Ordered the sensor, 3 weeks until arrives.
Question…from the online repair manual and the diagram of the part…I can find at the bottom of the engine the 2 bolts that hold it into the engine, but I cannot see how the wire fits in? Anyone have a video, diagram, or explanation of how it is replaced? Greatly appreciated.
