1 - 10 of 10 Posts
Was wondering if anyone has painted the chrome piece on the top of the tank that is around the speedometer? If so any tips, as far as prep & what paint was used?
I have considered using black Plasti-dip on mine. I used it on the straps of my windshield last season, and used something similar from Rustoleum, called Flexi-dip, on the wheels of my Wrangler. I like the idea of being able to remove it if I change my mind. The stuff also protects and inhibits rust. Just a thought. - But if you want a cheap spray can that's permanent, I recommend the Rustoleum spray cans. Coverage is wider and smoother than Krylon, IMO.
1. lightly buff the part with 500 wet/dry paper
2. wipe part with acetone.
3. put two or three coats of self-etching primer
4. lightly buff primer with 500 or finer, wipe with tack cloth
5. paint
6. clear coat.
All this comes in a rattle-can, you can use the spurge's with wet/dry on them and this will give you a good paint diy job.
plasti dip
I like the idea of plasti dip, I'll pick up a can or two & hit the speedo part & the coil cover while I'm at it.
Dumb question, on the 2012 does the chrome trim come off the tank just by removing the one screw on the top & sliding it forward. Or are there other screws hiding?
Is that chrome plated piece metal or plastic?
only reason I ask, if its plastic I would not wipe it with acetone.
there are two screws in front of the speedo, and one behind it
1 - 10 of 10 Posts
