1 - 2 of 2 Posts
Forum Members,
Looking for some insights. 2007 Roadliner...18000 miles on it....cobra exhaust, Power Commander V.....all is running great.
I installed the PCS slam kit (dogbones and spring) and after that I have a driveability issue.
Between about 1600-2500rpm I occasionally a split second blip in performance...happens after riding for 5-10 minutes. It has happened in every gear I think (can't remember if in first or not..but all others). It does a slight, what I would call "buck", not big..but noticeable...almost feels like the engine hiccups, or the belt is slipping...but feels like the engine does not power back wheel for just a moment..split second. I have checked belt tension and is within the 10lb specs..and the belt itself is missing no teeth or damaged that I can see.
I can imagine putting bones and a spring it it could cause this issue out of nowhere...coincidence?
Any ideas on what might be causing this? Things to check?
Thanks in advance for any advice,
Jim
Sounds like a spark plug or ignition issue.. or since you have the PCV ..have ya checked the maps or changed the maps lately ?
Lowering it should have no issues with performance.. did ya forget to connect anything during the spring/dog bones install ?
1 - 2 of 2 Posts
