Lots of posts in here about buffeting so thought I would share photos of my Memphis Shades lowers on my V Star 1300 and maybe help some people, using this as a starting point to get their lowers set up and get rid of ALL buffeting.
The photographer insisted I put his photo at the end of the slide show.
Stats -
1. My height - 5'11"
2. Windshield is a stock Yami 19" Med Windshield. (19" from the top of the headlight cutout)
3. Memphis Shades Lowers
FACT - I NEVER, EVER, HAVE BUFFETING.
When I bought the bike buffeting was horrible, then I bought the Memphis Shades, guess I got lucky and lots of thought, anyway less then an hour installation and I never had buffeting nor have I had to adjust them.
I THINK, maybe people try to install lowers fitted up tight to the windshield, I intentionally left a pretty big gap, simply because I wanted air, clean air, it worked perfect. (Photos 13,14,17 show how big that gap is)
Think of the lowers as air deflectors, deflect the air around you, don't try to stop it, its not possible, think of it this way, in your car, turn on your A/C, turn the vents so the air just brushes over your armpits, shoulders, over the top and side of your head.
I get a steady stream of clean air from between the gap of the lowers and windshield that comes up around armpit height over my shoulders and over the top of my helmet.
Like I say, I got lucky, but I did give it thought, my objective was to get a smooth steady stream of air not block it all off because that is impossible, in fact, trying to block it all off is what creates buffeting.
ANYWAY I NEVER have any buffeting issues, never feel unsettling turbulence, well up to 90 MPH anyway.
Here are photos, hope they help someone ...
http://share.shutterfly.com/view/flashShareSlideshow.jsp?sid=8AYt27NuzbN25H
Thanks for posting pictures. Set up is not much different than what I have. I am using Bucks lowers and it doesn't seem to make any difference where or how I position them. The buffeting is still there. I have the standard tall (23 inch) windshield and I also bought a 19 inch Cee Bailey. Doesn't seem to make much difference which shield is on the bike. I prefer to look over that's why I bought the Cee Bailey. I did get some improvement by jury rigging the Buck lowers and moved them down about 4 inches. I am only 5-8 and have new Nolan N104 with a Sena communicator on the side of the helmet. The Sena may contribute some to the buffeting. I am going to take the module off and ride without it today to see if that is part of the cause. Looking at MS Fork Deflectors or going with the Star Deluxe fairing, but don't really want to spend the money on either without some idea if the buffeting will go away. Love the bike, hate the buffeting.
Buffeting is limited on my set up as well. Well, it was. I had the medium screen and Harley lowers mounted high. THEN, i added the passings lamps and i have buffeting again. Im going to try a set mounted lower. Back to figuring out what will work now. I think its dependent on a persons height, seat type, windscreen, and a few other things.
sorry, can't seem to get the link to the pictures to work. am i the only one that it does not work.?
Just guessing, but it may have something to do with Adobe Flash (or the lack of it). I can view the pics on my desktop computer (which has Adobe Flash loaded), but I cannot view them on my I-Pad (which doesn't have Adobe Flash).
Stats -
Doug,
Just to confirm, you have not made any adjustments to the tilt of the windshield, is that correct?
If you're using iPad just install the Puffin free browser. I just cut and paste to it and it will show Flash content. I just tested the above link and it works just fine. I think it uses a proxy and doesn't work 24/7 but it should do ya good.
