I switched to customade drag pipes. I just installed lollipops for some backpressure. However on decel it has a nice little pops happening lol.
It technically would be running lean at this point correct?
Can I get away with adjusting screws and how much of adjustment should be made?
Thanks all
You will still get some popping, it just shouldn't be as bad. I put in some homemade baffles and still get a pop from time to time. Also may depend on the size of the lolippop, if it's restrictive enough or if you have a leaky gasket. That's about as far as my knowledge goes on this matter.
If there is a exhaust leak I can't hear it lol.
I'm debating on playing with the carb screws since it runs really good otherwise.
Put in some lollipops and that helped all around it seems like. Adjusted the idle a little bit and that seemed to cut back the popping.
Like Nick says....it's your PMS. Backfire on decel indicates a lean condition with the throttle closed. Turn those screws out like he said and your problem will go away. It's just a normal part of tuning...
