1 - 2 of 2 Posts
I have a 2002 Vstar 650,I took the rear end off to replace the rear tire,when I put it back together it tightens up so tight that the wheel will not turn.The clearance between the drive hub and the wheel closes up.What the heck is wrong.
You are missing a spacer. Do you have this tube in the middle that your axle goes through? It keeps the hub and the brake drum separated.
1 - 2 of 2 Posts
