I am thinking about putting in a progressive rear spring. I put Cobra Speedster Longs on my bike and now they tend to bottom out if I am going around a right hand turn with a passenger on and we hit a good bump. Already have the stock spring two clicks down from full so I think my only choice is a progressive one.
Anyone have any recommendations on them?
And did anyone do the install themselves?
did it make much deference in the ride?
Then Bike is a 2002 1100 custom
Thanks
I don't know if I can offer much help, but I just installed a progressive spring onto my 650 as part of a larger build. I haven't finished rebuilding the bike so I haven't test rode it yet. I got the shock with a lowering kit from pacificcoaststar.com. What I can say it is a bear to change out the eyelet on the top of the original shock. I had to cut mine off after a couple of hours trying everything else. And even then it was reluctant. After that, it was a breeze to put in, provided you have motorcycle spring clamps. I used auto to get the original off, but needed smaller cycle clamps to get new spring on.
Are you referring to the entire set-up or just adding a progressive spring to the stock shock? From what I have heard others say (no personal experience) the swap to progressive was one of the best mods they had done to the bike.
If your bike has about 20,000 or more...it's time to replace the shock. A spring is a band aid that may get you by for a short time, but you'll have to live a worn out shock (some things a spring can't fix).
Put a Progressive 465 shock on it and you'll see what you've been missing. It's one of the best things I ever did to mine.
I agree with Sick Mick. If the shock is gone then a spring is a band-aid, especially if the bushings are worn. The spring swap is not that hard if you're careful. The eyelet swap was a bear but not necessary unless you're lowering the bike.
