It's there for me, here it is a little bigger.
Just so people know the correct touch up paint can be found here: https://www.colorrite.com/wizardresults.cfm
It is called Dull Red Metallic D (DRMD), not sure why the color name used by Yamaha calls it Raspberry Metallic Red because even in the Yamaha parts catalog it shows the color for the cowling parts to be Dull Red Metallic D.
I guess Dull Red Metallic D just did not sound as good as Raspberry Metallic Red.
You need to purchase the base coat as well as this is a tricoat type of paint. You apply the base coat then the top coat and then the clear coat last.
IMPORTANT NOTE: Some colors require a base color to create a special color effect. This is called a "TriCoat" which is Base + Top + Clearcoat. If your color is a TriCoat, the base color will be listed below under "ColorRite Base" and you will need to order both the Top and Base listed. We always recommend clearcoat for the proper match and maximum protection.
