1 - 9 of 9 Posts
Hi All, I am new to the Yamaha Roadliner and I am having a little trouble. I have a 2006 Roadliner Midnight that I bought used. The bike has throw over saddle bags that I do not like with bag supports. Today I tried to remove the saddle bag supports and I ran into one problem on the very rear fender support bolts. When I was removing the very rear bolts (towards the taillights) I used a 12mm spanner and the left side bolt was a little more stubborn than the others and I stripped the outer edge of the nut under the fender. There is only about a 1/4 of the nut bearly sticking out and is now stripped. Any ideas on how to remove this?
Thanks for your help.
Sounds like you will be getting real friendly with your drill that might be the only way to get it off now
Sent from my Motorcycle iPhone app
Thanks Sgtcuts,
There seems to be a little bracket where the bolt is located under the fender with a gap, I am hoping that a thin 12mm wrench will fit in that gap. I am wondering how others may have taken the rear fender off and how they got a spanner on those bolts.
Thanks again.
Banned
I was thinking that those nuts are welded in place to the underside of the fender. Perhaps the PO broke them off and put loose nuts on as a replacement???
It is hard for me to fully imagine a picture of what your describing ??
I wonder if an easy out would work. I would call an auto parts store and see what they say. I also wanted to remove my rear struts but loctite has a serious hold on the ones closes to the front of the bike. Has anyone tried heat. I'm worried about screwing up the chrome.
use of heat.
i believe you can carefully heat the loctite with a heat gun or small propane torch. the loctite breaks down around 350 - 500 deg. you should be able to find this info on the net. this low heat wont ruin anything if you are careful.
Thanks Brain, I think there is an inner fender support that holding the rear fender strut nut in place. This is the reason only a part of the nut is accessable but also allows for a very thin 12mm spanner to fit between in outer and inner fender. I will try the heat though. The PO may have over tighten the nut. I was able to get the right side off with no problem but the left side rear is giving me a problem.
I don't have the factory service manual yet but it's on order.
Thanks again.
Thanks again.
Just an update, I purchased a set of thin flat metric open ended wrenches and this did the trick. If anyone ever has to remove the back fender rail bolts, there is an inner fender support that holds the nut in place. You have to be very careful when removing these nuts. The thin wrenches were able to slip between the fender and inner fender while I used a allen wrench on the rail bolt.
Thanks again for everyones help.
I had problems with one of my fender bolts too. Turned it into a 2 person job to clean up the threads on that nut. My buddy held a tap from the inside while I turned the nut with a 12mm wrench, little by little, and afterwards it all worked just fine. Must have overtightened that bolt a lil bit when I installed the saddlebags...
1 - 9 of 9 Posts
