2007 Road Star 1700
Hi fellas, I want to remove my sissy bars and need to cover the empty spots where the bars insert/mount. What is the name of these "caps"?
Help will be appreciated.
I've heard of guys with a Landon Bar (basically a loop that goes between the uprights with a contour to match the fender) but I believe they are difficult to find and pricey. Not sure about "caps".
As an alternative, why don't you just take leave the side brackets off? Either put the eyebrows on (they can be found on eBay etc. for not too much $$) or if you have saddlebags make some spacers. Might be a cleaner look depending on what you're after.
Don't know if you found caps yet, but if not, just google square tube caps. I'm sure you will find something that will work and fit.
Cheers
Al Jones
