Does anyone have any info on removing the AIS from a 04 vstar 1100?...been lookin around on google but all i find is general info.....does anyone have the specific intructions on what to remove and. What to use to block off the system?..
a lot of guys use shell casings as plugs.... a cursory search on this forum will give you more info than you could possibly need on how to do this mod.
I used the 45 acp shells and saved that cash for another toy. If you have a gun club near your place just go and ask them for a few spent casings. They should give them to you. Just make sure you use spent casings and not new ones.
Damn , im a .40S&W owner and have plenty of spent brass casings layin around.....do you think it would be possible to use a .40 caliber?....if not ill just head over to the local gun range and collect some..
I'm not really a gun person so I can't help you in that dept. As an aside, I rewrote the AIS removal from Jstar in a Word document. If you want I could pm you this file. It's easier to follow than on the forum. Also once the elbows are loosened, I used a large allen key to wiggle them out using the lasso Jsatr mentions.
If you don't want to remove the elbows going into the heads a 38 casing fits nicely.Maybe overkill but I put a little grey rtv on the outer shell and started it. I tapped it in with a 3/8 socket extension and a ball peen hammer. 357 should work as well though it is longer than the 38. I used one of the small Allen head screws that held in the assembly to screw into the small hose that goes to the carbs. I then stowed it out of the way. When I have the tank off I'll plug it at the carb. I used the brass ones, not the steel.
Is there something that I could find at home depot that I could use instead of the .45 casings for the plugs??.. non of the ranges here are willing to give me any , i dont know why.... what else could I use that I can find at a hardware store?
Done!!.... Thank you !! I really appreciate it, its been a real head ache trying to find spent casings around here in California, i guess this state being so terrified of many things people think that by giving me the spent .45 casings that im gonna use them to frame a murder or somthing.. hahaha
That explains why there was a marble in hose of my AIS, Whats the reason for blocking it?
