Slow turns should be done with rpm's around 1500-1800 rpm slipping the clutch, known as 'friction zone manipulation' the clutch lever travel has nothing to do with it, there is plenty of wiggle room where it's at, slow speed turns with clutch all the way out and low rpm is sure way to drop a bike in a turn under 5mph. With the lever set up as it is, you can tease the friction zone, something you cant easily do when you have to grab a fistful of lever movement, Yamaha knew that and they put a lot of thought into that idea.
Make sure your clutch lever is pointing slightly down so your arm and wrist are in a straight line when applying the clutch, so you don't have to reach out to grab it or have an awkward stretch.
Too many people want to make mods and crutch on the clutch, it's on many forums as you said Bob, but practice with bike you bought is the answer.
