1 - 2 of 2 Posts
2013 Roadliner
Wondering if anyone has any suggestion when it comes to removing the rear fender on a Roadliner. My turn signal came loose and I stripped one of the Allen heads trying to remove the tail light. My thought is taking the fender off will make it easier (or at least possible) to deal with the stripped Allen head. Any helpful comments will be appreciated . Thanks.
2013 Roadliner
Discussion Starter · #2 ·
Just closing this out. I removed the rear fender by (1st.) removing the rider seat bracket and the tool kit tray (2nd.) I unplugged the rear fender electrics (tail light, turn signals etc.) found under the ECU in a “black plastic wrap or bag”. (3rd.) I removed the four fender bracket bolts (two each side) located closest to the rear of the bike. I then lifted the fender off the motorcycle, flipped the fender over and did what I needed to do.
1 - 2 of 2 Posts
