1 - 2 of 2 Posts
I have an 03 Vstar 1100 Custom. I have replaced both the front and rear turn signals with LEDs, LED flasher and replaced the turn signal switch. I've also checked the signal fuse and it's good. I'm unclear if I may have the wires scrossed on the flasher. It's a 3pin flasher-one "horizontal" and two "vertical". I have 3 leads-a single brown wire, one with multi-colored wires, and one with what appears to be Browne white or brown and yellow.
Thanks for your help. Pictures are a
Ways helpful!
1 - 2 of 2 Posts
