Fuse
Edge,
The fuse for your Roadstar is also behind the left cover. Hope your passing lamps were installed correct you will add about five amps more load to the fuse they are installed on. Should be OK on the head lamp fuse, unless the bulbs were changed to 55 watt bulbs.
You can find your owners manual or a parts manual at starmotorcycles.com, under parts and service.
