2002 V-Star 1100 custom speedometer started bouncing down to 0 and back up, then the odometer cut out and back on. Looked at some threads on the subject which suggested fuses, bad ground or wires worn and shorting out. In my case, the battery connection screws had come loose over time, making a sporadic bad connection. Tightening screws solved the problem. :)
thanks, smoother roads would help. Seriously, I just try to keep it between the ditches with the rubber side down!
