Itd be awesome if you’d just explain it here so you don’t have to do it multiple times.I went thtough this.....it's not easy to do.
Requires a scope and a signal generator
If you want to know how it's done, PM me, I'll walk you through the process.
Basically the scope is used to obtain the frequency and form of the drive signal for the instrument (at the instrument)Itd be awesome if you’d just explain it here so you don’t have to do it multiple times.
How fast of a scope, and how good of a signal generator?
ok. So a square wave generator with a variable frequency and a 20 mhz scope… but how do you figure out corrected output when it varies depending on speed?Basically the scope is used to obtain the frequency and form of the drive signal for the instrument (at the instrument)
The signal generator is used to apply an input (VSS) for the instrument on the bench.
I have a 99 Roadie that needed a better speedo, all I was able to find was a unit that was left over from a warranty claim that worked but was off by quite a bit.
There is a trim capacitor on the early Roadie's board for calibration. Most instruments (automotive and motorcycle) from the 90's have these, on later style clusters the calibration is carried out at the software level.
Correction factor is obtained by comparing GPS indicated speed to instrument indicated speed.
Requires knowledge of how to run a component on a bench.
I have a Snap-On Vantage Ultra scope and a Pico 4 channel setup and an AES signal generator.
Any scope suitable for automotive is plenty fast enough.
Don't remember exactly what waveform the roadie was as I did that repair over a year ago, most speedos I see run off of 5V 50% duty square wave.
Don't use raw signal (sine), must be the same as the buffered output.
Like I said this isn't easy,
The only reason I did the Roadie's speedo is because I have the equipment and work on 4 or 5 speedos a year.
A Speedo Healer is plug and play and much easier........
I try to get them as close as possible around highway speeds. My Roadie was like that.ok. So a square wave generator with a variable frequency and a 20 mhz scope… but how do you figure out corrected output when it varies depending on speed?
Exactly that.I think what he is asking is when hooked to the scope and injecting the signal, how do you know what to look for. Is it indicated speed, is it a balancing of the signal? What are you looking for?
That makes a lot more sense. Thank you. I can build a signal generator with an Arduino and I have a, frankly, really nice Rigol scope. Using the test equipment wasn't the issue, it was using that equipment to fake a signal to the speedo that didnt quite make sense.Say your instrument reads 60mph, GPS indicates 55mph actual= 5mph overeport. I use the sig generator appy sig to the instruments input to bench run it to indicate 60mph, then using the trim adjustment bring the needle to 55mph.
I only use the scope to find what waveform the instrument needs to see so I can run it on the bench, also allows me to see if sig is clean.
I'm not altering vehicle's signal to the instrument, just the instrument's response.
Good to compare speedo/ GPS discrepancy at different speeds to see if the error percentage is consistent. If it isn't I concentrate on accuracy at highway speeds.
