So I'm bombing down the road going about 45-50mph. I notice when I shift in to 5th gear I don't have much get up and go, and 4th feels a lot better, I can rev it up and get up to 60 if I want to in 4th, etc. I think 5th gear on the 650 is more of an overdrive. Is that correct? Certainly when I'm on the highway going 55-60mph 5th gear is the choice. But on country roads I think 5th isn't so great.
I don't use 5th unless I'm going to maintain OVER 50 mph, like closer to 55. To accelerate from that speed I sometimes downshift to 4th but it's not totally necessary, 4th will scoot you up to 65 maybe a little faster. But yes, anytime I'm going to be doing at least 55 or over for a long period, then 5th gear is fine. I feel 45-50 in 5th is too low for that gear. I've had my 650 for almost 5 years now so I'm used to the way it's geared. Although I still think it could use another gear for cruising the highway at 75+. It'll do it but there isn't much left when you get to those speeds.
A lot depends upon the terrain. I found that on the level or downhill the 650 did great in 5th gear at 50 or above. If I was pulling a grade I would stay in 4th below 55. If she's lugging, you need to drop to a lower gear. If she's loafing, go for the higher gear. There's no exacts in motorcycle shifting.
Augie
Yup, stay in 4th till 55 or so. Or like someone said, going downhill you can be in 5th. Its all about hearing/feeling.
Remember these engines can rev pretty dang high, safely, and stay there. If its lugging, shift down, you still have another 10-15mph to go :D
