1 - 20 of 77 Posts
700 miles on my new 950 and I am loveing it.
The fuel mileage is higher than I was expecting it to be.
I get 200 to 204 miles before the fuel light comes on.
That figures up 56 mpg when I used 3.53 gallons,
and 60 mpg when I used 3.39 gallons.
I wonder why Yamaha estimated 47 mpg ?
Any one else get that kind of mileage ?
It seems that Yami/star, have a good habit of being on the more conservative side meaning that they tend to go under the MPG
example VS1300 says 42, many people get 45ish
VS650 says 49, I get around 50.
Its a good thing you know.
Discussion Starter · #3 ·
I am not complaining but how does a 950 get higher miliage than a 650?
I filled up again yesterday 57.85 MPG.
4 valves (950) per cylinder vs 2 (650), means that the bike does not need as much fuel since it can breath easier.
FI (950) vs Carburettor (650), gives a much more accurate dose of fuel.
and finality the Belt drive is about 2-3% loss compared to the shafts roughly 6-7% loss of energy.
in short, more energy/ pull with less gas.
Also since the 950 can carry weight better it doesn't need to rev into higher RPM's as often as the 650, which I have to almost fly apart to carry my 300 lbs frame 70+ mph.
This was my first tank full on my 950 today. The light went on about 169. I don't know how full the dealer filled it. Rode to 183, and it took, if I can remember right, about 3.6 to fill. I filled it up to the Vents
Does that sound about right. Did your mpg increase as you increase in miles
Thanks
Thanks
Doesn't sound right. Based on the numbers that you gave us you averaged 61 miles per gallon. I don't think that you'll get much more than 55 mpg with this bike, that's about what I average with my 950.I have 545 miles on mine and I'm not hard on the throttle.
got about 650 miles on mine, and my light routinely comes on around 160 miles, and i fill to the vents as well. i weight about 240 lbs and hit at least 70mph every day since i take a highway to work.
if you're getting 60mpg, i'm guessing you're lighter and don't open up the throttle very much yet.
I have almost 1000 miles of city riding on my 950 and it gets an average of 44 mpg. A LOT better than the 12 mpg my '96 Explorer gets! :) Out on a country road, I'm betting that I get up into the mid 50's if not more like everyone else.
anyone else got a windshield? i'm guessing that may have something to do with my lower MPG than everyone else. if i hit 70 without a windshield it feels like i'm riding through a hurricane so i gots ta have it.
Good point. I don't have a fairing or windshield yet. However, I have plans to turn the bike into an "as-needed" tourer so that my girlfriend and I can ride with her parents on trips without feeling the burden of not having enough space and comfort. :)
I ride 60-75 mph back and forth to work. I have 750 miles on it and have been getting 48.6-49.3 miles per gallon. My light comes on at 160 miles or about that regularly. Today at 158.8 it came on. I fill to the hole the nozzle fits in about 3 inches down in the tank.
Sound about right? I really thought I'd get closer to 200 miles on a tank.
Fill the tank to the bottom of the plate in the fill neck and you'll get 200 mile before the light comes on. I came back from a 265 mile ride today and averaged 54mpg and I fill my tank to the filler neck plate, sometimes a little above it. I have 1567 miles on odometer. Why do fill the tank 3" low?
The round flat plate is where I was meaning. It is about 2 inches into the tank I guess not 3, with the small holes around it. I might lug the engine more than I should or something. I'm just not getting that many miles before the light comes on.
i get the same performance as you. if you think about it, when the fuel light comes on, you've got about 30 more miles before the tank is dry. puts you close to 200 miles, technically. for all those getting closer to 200 miles before your fuel lights comes on, i'm curious if you have windshields, your weight, how much you're hitting at least 60 MPH, how hard/soft you're riding your bike in general. i wouldn't say i ride my bike all that hard, but i do like to gun it a little more than others.
getting better than advertised mpg
I have been getting 59 mpg on my 950 tourer. It has been pretty consistent at each fueling. Most of my driving is on back country roads around 50-60 mph. I am of average weight and not carrying anything extra onboard.
Gas Milage
I've got the 950T with the windshield. Most of my riding is around town with 35 - 45 MPH. LOTS of traffic lights. I've had 46.5, 53 and 47 out of the respecive tank fulls. Get around 140 before the light comes on and it'll take between 3.1 and 3.25 to fill. The tank with 53 MPG had some highway miles on it.
what mpg depends on how hard you ride too and also wind condition.
I got around 50 mpg at speed 70mph,
decrease to 47 mpg when I ride 75mph
if I ride harder, let's say 80mph or above then I'd get less than 45mpg
1 - 20 of 77 Posts
