1 - 18 of 18 Posts
I replaced the starter relay assembly on my 1100. The new relay came with a 10amp fuse, the original had a 30 amp fuse, I have tried switching the fuses and the original 30 amp does not work. I did have it running with the new relay, but it's my first bike and it took time to figure out the clutch and gas balance. I rode it once and it struggled trying to crank but wouldn't I'm wondering if either the battery is not charging or if the charging system is not working.
I don't have a voltmeter and I think I'm going to clean the grounds after I replace this battery. I don't really trust this sigmas Tek battery. I was worried that something may have gotten on or around the stator or flywheel but it looks like the most I need to worry about is corrosion
Strongly suggest to pick a multi meter if you are going to be working on bike. Right tools make the job easier. $10.00 at Wal-Mart.
Also during my first ride I realized that the bolts that originally held the bags from the wheels where too long with just the chrome bits. I bent all four bolts and all but one I was able to remove. I drilled the head off is there a way to remove the rest without messing up the threads or The paint.
And after the battery I'm going to be taped out for a bit.
Easy Out extractors work pretty good. Google how to use and watch a video or two.
I'm not good at reading wiring diagrams would any of you know if the lower amperage fuse that's on the new relay keep the fuel pump from running fully.
I cranked the bike today and if I tried to cut off the choke or even touch the throttle it would die out, it feels like it's barely getting enough fuel to get the lower jet but not any other. The bike will out idle my patience but I'm not sure I had it running a week ago and the only thing that has changed is the battery.
The pump is probably trying to die on me and that's something I really don't want to mess with, I'm tired of taking the bike apart and putting it back together.
Battery is used for only starting a vehicle. The charging system takes over electrical requirements after that. The charging system tops off the charge of the battery so it's ready the next time you need to start it. The majority time a bike will not respond to choke or throttle it's a fuel deliver issue or carburetor problem. The lower amp fuse will not effect the starter relay effectiveness, but will blow fuse quickly if there is an issue. If you have at least half a tank of fuel the fuel pump really isn't needed. Many people eliminate the fuel pump on carbed Vstar bikes. The fuel pump is low pressure designed to keep a constant fuel delivery since part of the fuel tank is below carb floats. The fuel pump will only pump long enough to fill the carb bowls, usually less than 10 seconds at a time. There are many here that will assist in diagnosing your issues. Post what your bike is doing, or not doing, when you try to start it. Did it start then die. Or did it die when you moved the choke and or throttle? Would it crank back up. Was both cylinders getting hot? Did fuel pump click for a few seconds and the stop when you first turned the key on? Keep us updated.
Discussion Starter #9 (Edited)
Like I said the bike starts fine first time and sounds like both sides are working but if I try to take the choke off or throttle up in the slightest it dies out. I think I'm hearing the pump work when I first turn the key but nothing the second or third consecutive time. The bike will rev I roll or shake it back and forth.
With what I've seen online everyone says it's a fuel issue and they recommend cleaning the carb, but I have done that and it ran afterwards.
Sounds like a fuel supply issue, either before carbs or at carbs. Did you clean the petcock screen? Did you change fuel filter? To test fuel flow, undo fuel line on tank side fuel filter, put line in container and turn petcock on, good fuel flow? Connect line back to fuel filter, undo fuel line after filter, test same way, good flow? Connect line back up. Undo fuel line at carbs, turn key on to energize fuel pump, good flow? If all these items test good the issue is in the carbs. Post back results of fuel flow. By the way, you are turning petcock on and off between step, if you don't fuel will go everywhere, yes, that's experience speaking. 😀
It's a new petcock on the tank and I have drained the tank using the petcock and it flowed well. When change out some of the local lines I flushed out the filter but I need to replace it soon or now when I was taking the old line from the tank off I stretched the fitting and it has probably collapsed if the pump isn't failing.
I can't find the replacement for the bike locally other than the cheap lawnmower filters otherwise I would have replace it by now.
Any proper sized fuel filter will work. Check your local auto parts store. This is what I did years ago, no issues.
Discussion Starter #13
Does that have replaceable inserts or is the whole unit disposed of after it has been used up?
Discussion Starter #16
The jpcycle's filter is similar and the elements are 3 dollars but now that I'm thinking about it your way is cheaper with shipping, now I wish I hadn't ordered it, oh well I guess
Discussion Starter #17
New filter came in and it wasn't the issue. If it's not the fuel pump then it's one of three other fuel lines or maybe a vacuum issue, so it's either daunting or expensive or both and I just want to ride.
Discussion Starter #18
So in messing with the cheap relay I got the pump to work, so I need to get a proper OEM relay anyone know where an inexpensive one is?
1 - 18 of 18 Posts
