Under seat.
Automotive fuel system Motor vehicle Automotive tire Fixture Bumper
Link to repair manual:
Discussion Starter · #4 ·
Yes the solenoid is under the seat but wiring diagrams show a starting cutoff relay
I can’t find this
Starter cutoff relay under gas tank. I miss read your question. Number 23. What issue are you having?
Product Font Parallel Design Drawing
Discussion Starter · #6 ·
Starter won’t turn over
Replaced the selonoid
Will turn over if I flash the terminals on the selonoid
Have you checked to see if you are getting power from started switch to solenoid? Can't find the thread right now but once someone had a corroded starter switch that caused a similar issue.
08 Road Star 1700
I would check continuity between the two top pins in the solenoid they are the coil you should get continuity between those two if not coil is no good.
