1 - 12 of 12 Posts
Hey this is my first time posting on the forum well i have a starter problem that happened todayon my 2002 vstar 1100 the starter spins like ita not grabing but i saw that one of the starter bolts had snaped on the housing could that be my problem that my bike doesnt want to start?
That is not good, and an indication of improper starting procedures. You can fix that and re-install the starter to see what happens, but my guess is that the starter clutch is destroyed....
Ugh thats great well im going to try to see if changing that bolt can fix the issue for now... but i might as well order the starter gear and a new starter then
The starter may be OK...I'd take it apart and check it before I ordered a new one.
Yeah but the problem is that the starter housing bolts one is twisted and the other snapped i tryed to find new bolts but never happend.. I wanted to test it outto see if my starter gear i shot
By mentioning improper starting procedures I think he's referring to not advancing the throttle grip when starting the bike. Advancing the throttle grip also advances the timing which causes detonation and could damage the starter mechanism.
I have a question can i still push start the bike if it has a damaged starter gear?
I can tell you first hand, it happened to me. My starter pretty much exploded on me at a grub stop one day, both bolts sheared. You can bump it off if the starter is jacked, but I don't recommend it, only in an emergency. I bumped mine and got it to work with extreme caution. I ended up replacing my bolts and cleaning up the starter pretty good and it worked like a champ. Look, the starter clutch was fine, just cheap bolts. I work aviation, so bolts were no issue to get ahold of. Also, like the guys before me said, do not throttle the bike while trying to start it, bad ju-ju. I didn't do it, I just had bad luck. Good luck, and be sure to upgrade the bolts to something a little stronger.
Yeah i wasnt sure thats how i got it home i oreder a need starter it should he here tomrow... But is it still possible it you have a toasted starter gear to bump start or push start the bike?
yes.......
Discussion Starter #12
Got my starter today and put it in and she started like a champ!
1 - 12 of 12 Posts
