Update:
I checked voltage to the battery, it reads 12.58
I checked voltage after I press the start button, it only drops to 11.7.
I jumped the 2 posts on the starter relay to see if the starter would turn, and a very little spark happens, and thats it. No power to the starter.
I unhooked the starter wire, and put + to the starter, nothing
I checked the connections at both the battery, and the relay, and the ground, they are all tight
this is where i get confused..
If I push the starter button with the bike in neutral, and the clutch left alone, and the kickstand up, it makes the buzzing noise.. if I pull the clutch in, leave the kickstand up, and push the starter button, the headlight goes out, and the bike does NOT buzz, it just "clicks".. if I put the kickstand down, the starter relay buzzes wether the clutch is in or not.
I've replaced the starter cutoff switch, and the starter relay. The starter cutoff switch was from a Yamaha dealer, but the starter relay was from a junk'd bike at a salvage yard.
Wheres the guru that knows about all this stuff? Please help
