1 - 2 of 2 Posts
when checking the ac voltage on a stator is it common to see up to 70 volts ac when running about 3000 rpms????
That's perfectly normal. You're checking the stator prior to the rectifier. At idle it may be around 16 VAC and it will rise with rpm. The key is the voltages are uniform between phases.
1 - 2 of 2 Posts
